clifford alarm
Car  clio 1.8 16v
hi all iv had my boot flushed on my valver and im going to wire a boot pop up to it i know u can have the norm central locking motor to do it but i want to wire it up to the boot button on my clifford key fob does any 1 know the colour wire it is from the clifford control box its a clifford arrow 5 by the way or if any 1 knows were i can get the wiring pics from for the alarm thanks
The wire will be the Grey/Violet or the Grey/Blue depending on which button you want to use. You need to set the timer to minimum and you should make sure the channel you choose only operates when the alarm is disarmed or you will be forever forgetting and setting the alarm off by opening the boot.
DONT use a central locking motor, it will last about 10 operations then pack up, they are not designed for this purpose. Get a solonoid kit (#60-220) from Clifford dealer or Ebay. or look on
http://www.electric-life.com/typeofkits.asp
You need to put a relay in circuit as the output from the alarm will only handle 200mA.
PM me and I will send you the wiring diagram.
iv got the max-power book and tryed to fit it the way they say but my boot on my vlavers not the same as that any 1 got pics of a boot-popper in a valver boot plz help
