Clio 1.2 200 plate sun roof leak (Ithink)
Car  saxo Vts
Hi,
My girlfriend has a clio on a 200 plate and lately there has been a leak over the front passengers head. now i can only assume that the sunroof seal has failed.
Is this a common fault on the clio?
If so can you use a seal of a scrap car or are they a use once thing and have to buy i knew one from renault?
Matt
the mk1 had a bad problem. so mk2 prob the same. u could try getting a used seal from a scrappy. i tried doing this on my mk1 but it was worse than before.
i ended up sealing it up with silicone gel!
im sure some1 will be more helpfull in a min
