clio 1.4 sport engine running lumpy ?
Car  CLIO 1.4 SPORT
hi
bought a 2000 renault clio 1.4 sport today but when i started it it was running lumpy and the revs were sitting lower than they should and also when reved and left to idle it sounded like it was about to cut out on me .
now i was told that the car had been sat for around 4 months so just needs a good service to sort it .
now is it likely to be just a service needed ? (oil&filter fuel filter air filter and plugs ) or could it be anything else ?
also is the 1.4 sport a 8v or 16v ?
thanks.
If its a 16v it'll be one of the pencil coils. Unbolt them but dont unplug, start engine and lift off one by one you will notice a difference in engine note on the ones that work. We play the coil pack lottery at work on Renaults £1 a go. If you lift one and the revs dont change but you can hear the coil arcing it could be a plug if the car has sat a while.
Open the bonnet, an 8v will have plug leads going to the front of the head. I'm sure the 1.4 Sports are 16v though.
As above, could be the Coil, leads, plugs, valve clearances or a burnt out valve. Its difficult without listening n looking.
so what is the possible causes of lumpy running and it sounding like its gonna stall when taking my foot off the accelerator ?
Common fault is the coil pack on these I would change that with plugs
But I would get it plugged into and see if there is any other faults that could be up with it
well today i went to get the spark plugs for when i get it tomorrow .
can anyone give me a guess to the symptoms if its gonna be the spark plugs or coilpack at fault or anything else ?
It might give you a better understanding of what is wrong or might not depends what it throws up and if you get one that you can read live data
so is it likely to be the coilpack if the spark plugs dont sort it ?
it sounded quite dull which would maybe be it missfiring ?
Without having the car in front of me and trying to diagnose the fault over the internet I would be changing the plugs, leads and coil pack !!! As this is a common fault for rough running
As this is a cheaper option and are serviceable items anyway so even if it's doesn't cue it, it won't be a big loss just means they won't need to be touched for a long while... Preventive maintenance and all that jazz
Or someone on here near you may have a diagnostic tool to plug in a get some info for you for beer tokens ???
hold on, if you had type the correct reg in on eurocarparts, it will find what engine you have, that result bringing up 16v must mean yours is a 16v not a 8v :S
ok will replace the spark plugs and see what happens then the coilpack and leads :)
also could the spark plugs leads and coilpack cause low idle speed and and nearly cutting out after letting the gas pedal off ?
if its not these what else could it be ?
ahh i see, slightly confused as reg's i usually put in come up with the exact model engine type.
also if its running slightly lumpy, have a look at the tdc sensor, if needs be clean it up. ( as for the location of it on your engine, i havent a clue)
could be to do with the air intake side aswell gonna buy a haynes manual for it and get on with the jobs :)
gonna check the spark plugs and replace
change the ht leads and coilpack
check the cts and tdc sensor and idle control
should be one of these i think .
but will see when i get the car tomorrow :)
yep buying a haynes manual off ebay tonight so will be here in a few days gonna fit the spark plug tomorrow after picking up the car then i will scan the rest of the items to see if i can see anything that it could be :)
will be back if i need any help :)
changed the spark plugs today and made no diffrence at all :(
if its not the plugs could it be the leads or not
also the thermostat is not working either as when i go faster the temp goes down
also the gearchange is quite stiff so what could be up with that ?
also the car seems to be using alot of fuel at a guess £10 got me 55 miles ?
what could that be ?
