I've having a issue with my 1.6 at the moment, 9.9/10 times I start it it doesn't run the high idle and when I change gear the revs drop off practically instantly and I'm having to blip it when I change gear to keep the changes smooth although it doesn't stall.
Though every once an again when I start it does it what it should and runs the high idle and it also catches much more easily you only have to give the started a quick flick and its started whereas it take a good few turns to get it started when its not doing what it should.
Then when its started its idling at about ~600rpm, not the 1200rpm or so when its working properly
Once i've driven literally 400m it starts acting normally and is fine and it doesn't do anything it shouldn't, I'm thinking the ecu isn't using the cold start map and injecting the extra fuel needed, possibly a duff sensor of some sort.
I'm just wondering if anyone else has experienced this or is it normal ?, i've got a years extra warrenty on the car because I got it from renault so will be taking it to them but as its not causing it to stall or stop when its doing it i've got a feeling they'll say theres nothing wrong with it so I thought i'd better ask.
Any replies or ideas are welcome and will be much apprenciated.
