clio 172 climate control and heater system
hi guys. recently brought a 52 reg 172, with climate control, the actuel box works fyne no problems with box but it doesnt blow hot air or cold ait out if i turn it up or down, it has a built in sat nav to so i dont no wether any wires are conected or not, plus if i turn the system on a funny smell comes through like a dry burnt smell kinda thing, difficult to explain, when the systems off some cold air comes through to my feet thats it.:S. just wondering if anyones had the same issue or anyone could help me id be very very greatful,many thanks. Elliott :D
mine does the same mate, ive read up on forums etc and its something under the wiper scuttle panel which is apparently a common fault with these. i cant remember the exact name of the part but its a fairly cheap part but a nightmare to fit apparently. type the problem in on google and eventually you will find out what it is. hope this helps
I wrote a guide to this it's in the guides section.
(or look at my previous topics and you should find it)
Relatively easy if you're handy with a soldering iron.
Thanks benkay, well its my 2nd day on here so im useless at it at this moment in time. Any change you could copy a link to me and id be really greatful,many thanks
