Clio 172 Cup Windscreen replacement- Mystery solved!
Car  Clio 172 Cup
Hi all,
To provide some help and guidance out there to owners who need to replace their 172 CUP windscreen, I have just been through this process (due to a crack) and it is not straight forward in terms of making sure the right one is fitted.
If you provide your registration and chassis number, you can still end up with the wrong windscreen which is what happened to me.
Firstly, the 172 CUP windscreen is:
NOT solar/UV coated
Has NO rain sensors etc
If you are incorrectly supplied with a solar/UV coated screen, there will be a small and very noticable "cut out" rectangle at the bottom-center of the windscreen. This is to allow French automatic toll booths etc to send their signal to the 3rd party reciever that will be mounted in a car for French drivers. The UV blocks this, hence the "cut out". This is the windscreen that will likely be supplied, which is incorrect for the 172 CUP. Make sure you check this when they turn up to replace your windscreen.
As the 172 CUP windscreen is not solar/UV coated (therefore no rectangular cut-out) and has no rain sensors, instead it has a very slight tint instead; blue or green. You will probably need to explain this when sorting a replacement windscreen. I found a post from 2008 which has the Renault part number for the tinted screens which I then gave to National Windscreens who were doing my replacement (mine was green).
Green tint: 7701066906
Blue tint: 7701066907
These part numbers still work. National Windscreen's gave the green windscreen part number to Renault and they ordered one for me- very good!
For extra information, these are the same windscreens fitted to the bog-stadard 1.2 Clio's.
Before fitting:
Just bumping this, has anyone bought one of these windscreens using either of the part numbers above?
Mine is in desperate need of replacement and just wondering which one people went for?
Just to update this, rang Renault and according to my reg mine is the Green tint 7701066906
Following on from this, my 182 non-cup needs a new screen, I assume the same applies to the 182 as the 172? Also best places people have found to get a new screen fitted? National Windscreens, Autoglass, Budget windscreens... cheers
UPDATE.... Yesterday (one day after calling them!) Budget Windscreens came and fitted a new windscreen to the little 182 RS. Could not be happier, £210 fitted on my drive.
Two other companies spoke to, one quoted over £400 and the other couldn't quote from my reg. and needed me to do a paper test (fair enough, they needed to be sure on green or blue tint). Budget said found out mine was green tint before quoting.
The installer was experienced and knowledgeable (wasn't his first Clio) and a really decent chap. Even explaining that being old the screen rubber surrounds could snap when removing them to extract the old screen (although this wasn't mentioned beforehand, for reference RPD has them for ~£34) but would do his best to get them out intact, which he did, 1 hour later he'd had the wipers, scuttle and old screen off the car and new screen in and all done. Couldn't be happier, car now finally looks amazing (or will do when I get round to sorting out the light lenses 😂 ).
Should add mine is a 182 non-cup RS. And I paid direct as insurance excess was £175 if used there approved repairer or £455 if I didn't!!
Did they fit an OE spec one? Is it Triplex glass etc? I need a blue tint one for a normal 172 with the square cut out bit and sensors.
Hi, I guess so, looks identical to the one taken out (minus the big crack). I've not looked for Kitemarks or whatever marking they need. Will check next. Easiest thing is to call and ask them.
Thanks, yeah I'll give my local one a call.
