Clio 172 PH1 Rally Car - Fuel pump starts after ignition switch off!?!?
Car  Clio 172
Morning.
I have a Clio 172 PH1 Rally Car.
Engine is mechanically standard, although the ECU has had the airbag stuff and immobiliser / alarm removed. It also has locking / unlocking from the key. Last night I noticed that after a short period of time (about a minute) after turning off the ignition, the fuel pump comes to life. It continued to run for a few minutes and eventually I disconnected the battery. The car is usually storeds with the battery disconnected. The car starts, drives absolutely fine.
Does anyone have any idea what the problem could be? Is it a problem - is there some kind of warm down going on?
Thanks.
PS, post above should say no remote locking / unlocking from the key, I have to use the key in the door.
The fuel pump has a relay in the engine fuse box. Maybe its stuck in one position or there's something problem with the live from the ecu which controls it
