Clio 172 Ph2 Cruise Control
  Renault Clio 172
Looking for some help following retrofitting cruise control to an early phase 2 Clio 172 FF (02 plate) that's with a gearbox speed sensor.
The retrofit all seems to work fine apart from neither the speed limiter or cruise control are smooth when enabled, seems to be jerking and lurching. The set speed will also sometimes flash during this.
If I sit at a stead speed (70mph), each time I press the '+' buttons the speed on the set display will vary between 67-72mph. As the speed sensor was a pattern part I've changed it for a Renault unit but the symptom is still the same.
I have access to Renault Clip if any settings need changing
Any help would be greatly appreciated.
Michael
