clio 182 cup, lowering wheels spacers
Car  cliosport 182
hi, new to the forum after selling my focus and buying a clio 182, happy with it overall but want to start modding a little,
so my questions are:
is there any way of dropping the clio a tad on standard springs or shocks of a trophey, i think i have cup suspension already, as i measured the shock bolt spacing = 60mm
and i wanted to space the wheels out slightly, using spacers, what type should i look out for, cheers
eibach springs are rated on here. coilover choice is a bit limited due to the 60mm bracket. spacers: get hubcentric ones and keep in mind that your wheel bearings may suffer from the widened track.
thanks for your reply, do the eibach springs come as standard on the tropheys? or are they a aftermarket upgrade
Aftermarket upgrade. Kam racing are the cheapest iirc. Great spring for day to day with s small but noticeable drop. I had them on my 1.2 for 6 months before coilovers and they are very good!
I also have spacers from eibach. Go for hubcentric and you'll need longer bolts.
