Hi. Im trying to solve an electrical issue with my doughters car. Simple put, no spark, fuel pump not engaging, immobilizer light steady on. As I understand the fuelpump relay gets input from the ecu. Relay is live and ok, no trigger. Then relay 7 is "engine control relay", which i understand is the ecu supply? Relay also ok but no trigger, thus no power to ecu. Earth wires confirmed. Is relay 7 triggered directly from the ignition switch? If someone could share a wiring diagram I would be thankfull
