Clio 2 1.2 16V 2004 Wiring diagram needed
  1.2 16V MK2
Hi. Im trying to solve an electrical issue with my doughters car. Simple put, no spark, fuel pump not engaging, immobilizer light steady on. As I understand the fuelpump relay gets input from the ecu. Relay is live and ok, no trigger. Then relay 7 is "engine control relay", which i understand is the ecu supply? Relay also ok but no trigger, thus no power to ecu. Earth wires confirmed. Is relay 7 triggered directly from the ignition switch? If someone could share a wiring diagram I would be thankfull :)
