following on from our other thread:
http://www.cliosport.net/forum/showthread.php?734574-Clio-172-Cup-Race-Car-Info-Request/page2
we thought it best to keep things rolling in the projects section.
we planned to do very little after the first weekend. the jobs list comprised:
- fitting the headlight blanks.
- moving the seat up and back a little.
- investigate tyre rubbing on full lock [highlighted on the auto-x].
- eliminate play in gear linkage.
first two were easy, the third highlighted the need to hammer the arches as there were telltales all over. the rears especially worried me as the cage bolts protrude quite far down.
the linkage caused further headaches. basically the pivot on the box is loose and so rocks side to side quite markedly instead of fore/aft for gear selection. we tightened it the best we could but have plans to go oversize and machine a bronze bush. more to follow on this one.
so, with that all done we brimmed the tank..............and found fuel to be pissing all over the floor!
we have a boot tank filling the oem tank to give approx. 80litres total [to be confirmed]. it appears the oem breather has been fudged to stop fuel leaking from it when the top one is brimmed. this had failed. we patched it as best we could using a bit of fuel hose and jubilees but this meant about half a litre of fuel still escaped and we both got fuel burns to our backs, arms and head as we sorted it all out. not the best at midnight and the panic meant we did not take pics of anything else we had done upto that point!
so anyway, we arrived to the autodrome last friday with the car seemingly sorted. a couple of snaps of the typical thing we get on a trackday. caterhams are popular with all, there's a few ex touring cars [clio 3 and a mk5 golf in shot] and plenty of tuned jap metal. supercars tend to be visitors from other gulf countries and are almost always badly driven. the mclaren almost got a side full of nicole.
oh yeah, we have christened the car nicole.....
sadly our day ended before the car had even got properly warmed up. jase lost the brakes going into the last turn, pumped the pedal hard to avoid the wall and locked up/flatted the front tyres. with no spares we were relegated to playing mechanic for our friends and wondering how much this was all going to cost....
back at HQ, we got a good look at the tyres, which are fooked...
and found a very simple explanation for the brake failure:
the car has been sat for 18mths and so this has to be taken as just one of those things. the intact pads are glazed from overheating and the right front disc [the one the pad failed on] is scored.
problem now is that we have no idea what the calipers are. searching for the casting marks is drawing too many conclusions. our best guess is that the rears are std. 172 and the fronts are used on the mk1 megane coupe, scenic and mk2 laguna. any ideas?
front right:
rear right:
looking for pad options. performance friction or carbon lorraine endurance pads are coming out tops so far for a trade off between stopping power and longevity. what do you guys use??
we do need to find out what the calipers are from before proceeding as the seals are also shot. given as we need to import this stuff and there's another trackday on the 14th we need to get it right first time.
the search is also on for new tyres that don't cost the earth. got a lead on a set of enkeis with scantly used slicks but unfortunately the tyres are 185's so no good on their own and the inner rim fouls the caliper. shame as they look damn good imo!
also had a rear brake change to do on my jeep. loved the tyre size comparison!
so that's where we are for now. focus has switched from initial jubilence to making sure we are safe on track with a car that hasn't been run for a while. i noticed some of the studs have a little wiggle in them so we may replace the lot and also buy new nuts. calipers need servicing and we will look to sort the arch clearance.
other short term upgrades will be a silicon hose kit for the coolant side and an oil cooler. we also want to investigate a bigger rad. temps are starting to creep and it'll not be long before we're running in 30deg+ ambients. also having done track sessions we need to change the gearbox oil.
we'd like to use this thread to keep track of what we do to the car and to gain knowledge and info for how to maintain and improve it. any input would be most welcome!
front right:
rear right:
