Clio dci faults
Car  Renault Clio DCi 65
Hi,
Ive recently been having a lot of trouble with renault clio 1.5 dci. First of all injector 4 was below minimum threshold, but ignored it for a while. Until one the engine stop light started flashing and it cut out, on starting it back up it chucked out lots of black smoke and wouldnt rev over 2k. Replaced the injector but had to drill out due to being siezed since then its had a new head gasket, turbo and fuel filter.
The problem now is that it will only start with easy start, when starting without it runs for a couple of seconds and then dies. 2 faults codes that are present on my scanner are df002 and df132.
Any help would be greatly appreciated, thanks
Chris
Also keeps coming up with coolant temp sensor short circuit. Also when left overnight the battery manages to use all of its power?
