Clio Mk 3
				Hi all, looking for some advice as I have a problem with my car and a few different family and friend mechanics seem to thing its different things. Looking for some more suggestions.
I've never had any issues with the car before. On cold mornings I've had to turn the ignition twice a few times, but other than that, no issues.
I'll tell the story how it happened.
Sitting in a lot of traffic, decide to turn the engine off but keep the ignition off for about 5 minutes or so, when traffic flow starts again, I go to start my car but ALL electronics have gone, nothing at all. Nothing happening when I turn the key. Then about a minute later I get the electronics to come on, but dash lights flickering, lots of clicking from the glove compartment area and window wipers going nuts and when I try to start the car, all electronics cut out for about 30 seconds or so.
Fast forward a bit, the car will not start even with jump leads, just a loud clicking noise when trying to start. The car will bump start, every time, and after bump starting it will start up fine with the key for a bit. But then will randomly stop starting with the key.
All the relays have been checked and they are fine apparently, battery is reporting a voltage of 12.8v.
Sometimes the dash reports a problem with ABS and PASSENGER AIRBAGS. Which I've read can be attributed to a battery problem.
Intermittently all the electronics will not work aswell.
I'm losing my hair over this issue, any suggestions will truly be appreciated as I'm in a position where I cant be without my car for too long right now.
Thanks in advance!
Thanks in advance!
