Clio P.I Springs 60mm, Any good or just cheap?
Car  Clio DCi 65
As title says...
Are they any good or...
Will these screw my cars suspension up aswel if i dont buy shocks?
they are cheap also if your going for a 60mm drop jsut on springs ya dampers would not last long best to get a 60mm apex kit comeswith dampers and springs and costs 275 from ktec would be lot better and handle better to
I have the 55mm springs on my Mk1 from them. Been on for a good 6 months now and still going strong. But the ride is a lot "bouncier" now because the shocks are still standard. So if you can, I'd try and get a kit. :) But nothing wrong with the springs imo.
Well i'd only really want them for looks tbh
Just to hide the arches with my 15's!!
How many miles would you say that most likely last?
Hopefully getting a new car for my 18th .... March
A lot more expensive than buying the kit now. Specially if it fails while driving hard, could end up being fatal, so depends what you call expensive. if your not up for changing shocks, then 40mm drops prob better way.
Our 60mm Suspension Kits Start at just £200!
Spring Kits start at £49 but i wouldnt go more than 40mm on standard Shocks as others have said
Ok cheers anyway,
Going to have to leave my car for a bit as i cant do anythin to it straight away as its just back from garage and rents will go scatty on me!
Better start saving for shocks then!
ive got 40mm springs on my 172 been on about 7mths and so far so good.
the ride aint bad and looks mint with 17"s
