Black clio ph2 172
Hi
I'am new to the cliosport forum and thought i would share my tale of woe
Recently i done a oil filter change on my clio 172 and kinda got into trouble removing the oil filter
the last owner must of kranked the filter on so tight it would not undo by hand
i tried sticking a screwdriver through the filter and tried to turn it still no joy........ cut a long story short ( after loads of swearing and bruised arms)
the filter was F***ed..... the only thing left was the oil base plate stuck on the engine block...... I even tried tapping the oil filter base with a chizel still no joy
P***ed right off i knew i should of taken it to a garage.....
Anyways after a crappy night sleep worrying about the clio i decided to have another go...
i had a look through my dads tool box and found the removal tool you use to take off angle grinder discs with
http://i34.tinypic.com/2cpye5u.jpg
this fitted spot on in the oil filter base plate holes....after plenty of wd40 and loads of swearing the base plate started to turn........... and eventually came off
So if you ever get in this s**tty situation dont give up get your self an angle grinder removal tool and all your oil filer troubles will be gone
