What video set up are you using?
Tbh I'm not completely sure, it's a friend of mine who does all the incar footage for me, his YouTube channel here http://m.youtube.com/user/Sparcoxs?desktop_uri=/user/Sparcoxs
I think he uses the gopro2 as he thinks it better than the newer 3, but don't quote me on that because I haven't go a clue
Cool so it's a go pro camera, what about audio is the camera linked to your intercom?
I'm doing pembrey next week , but first event in the Impreza , I'm out next in the Clio on Epynt beginning of march , got a new front cross member , rad and bumper that needs fitting after the last pembrey , oops !!
Looks good Andrew!
Last time I had an argument with a lorry tyre I ended on my roof
Thanks ye them lorry tyres are surprisingly strong lol
Tbh I think I got away with it likely, I thought the damage would of been much worse!
We genuinely thought "if we touch one of those we will push it out of the way"
Hell no
What's your next event?
Haha learnt fast then
I think where going to do dale stages which is the 25th of May, gives us enough time to get the car sorted, top mount bearings need changing now as there is slight play in them and of course new front bumper and headlight also noticed a slight leak from the box so going to pull that out and sort that while where at it.
Are you planning to do any events soon?
Great result.
Hopefully mid summer caerwent in June
Good result Andrew , good to speak to you on sunday , the more time you spend in the car the better the times will get , they are great little cars and perfect for these kind of stages , we were going quite well until this
https://www.youtube.com/watch?v=Es5omH2sT2E
Then he tried to blame us for turning into him , prick !
We got it back to service and re-tracked it as something is bent underneath , luckily no panel damage as he caught us on the wheel
This is a clean stage we had , only a few seconds off the fastest car
https://www.youtube.com/watch?v=eA0yXqmipDQ
We finished up 9th overall , so not too bad seeing as we dropped a couple of minutes with the puncture
Long overdue update.
Got some big changes coming hopefully in the near future, going fully independent rear suspension and eventually fully wide track front and rear. Me and nick at pms have been talking for while and it's something that we are both interested in to improve the handling of our cars and stopping the picking up of the rear wheel.
Next event is prescot hillclimb October 4th and all being well prembrey stages the following weekend
Looking good!
Regarding going independent at the back, if you're looking to do some more hillclimbs etc you know that will exclude you from competing in quite a lot of things?
Unless you enter the car in the Libre class (at least thats what it's called in Scotland) basically the "do what ever you like class" so you would be in with some really serious machinery. Don't take that the wrong way, your car is very nice and well spec'd but a 2.0 fwd, vs a 600-700bhp awd space framed something or other is no contest.
Going independent at the back is obviously a nice thing from a technical point of view and if done properly it could save some weight but it won't in its self stop it lifting a wheel, which raises the question of why you want to stop it doing that? That's not a bad thing in a fwd car. Granted you don't want the car falling over (it is leaning quite a lot in that last picture lol) but that can be cured with spring rates/roll bars. Are you willing to disclose what your rear spring rates are?
Cheers Kenny,
The hillclimb are just for a bit of fun a lot less stressful and really relaxed atmosphere. the local llys y fran hillclimb run a 'rally car class' which As long as it meets the Msa rules for rally is ok to do any modification you wish. Again still not going to match the bdg and millington powered escorts lol
As for the independent rear setup there is a few reasons why I wanted to go down this route, firstly I've also wanted to do the wide arch s1600 kit just because I love the way they look without using stupidly large wheel spacers
Secondly as I'm running the front wishbone kit from pms without a front anti roll bar, without going stupidly high with the springs rates I'm always going to have a lot of roll from the front, to try and reduced the roll widening the track will help to reduce this whilst not using high front spring rates which won't be any good for Tarmac stage rally,
Thirdly having a independent rear I agree won't completely eliminate the picking up of the rear wheel but should reduce it. changing spring rates would help reduce the amount of roll and reduce the amount of weight transfer helping to keep the rear down but for Tarmac rallying running high spring rates on bumpy and broken Tarmac just won't work,
This is the s1600 rear axle which uses the original mounting points, but massively expensive!! Nick thinks that's we could produce something much lighter than this which like you said will help with weight saving
I did wonder what the set up was at the back of the S1600 cars, I'm assuming there must be another part that ties the inner pick ups to the chassis some how? I'm liking that set up though.
The S1600 cars all 3 wheeled so while they may have been independent I'd be guessing that was possibly partly to get the wider rear track?
Are you planning to fit a front ARB? Lifting the inside rear can help with turn in on a FWD car, it's doing nothing other than causing drag if it stays planted on the road.
Admittedly, setting a car up for a rally stage vs a race or a sprint is a bit different so what works for one might not be ideal for another.
Regarding the MSA rules about changing the suspension type, it was my understanding that they (MSA) generally didn't allow you to do this unless you went into the free for all classes, ie Libre
Reg: 48.4.1 does sound like it's to prohibit a change of suspension type, might be worth a chat with you eligibility scrutineer before you commit to anything? I've been keeping in touch with mine throughout the build on my car and have kept all the emails just incase I get any questions at events.
I sent my local scruit an email with the pictures you posted of the rear axle, no go for me up here
I need to caution you that I think that your proposed mods would contravene S 12.8.2 AND 3. Blue Book page 332.
Further, the fact that it has been homologated is another grey area as the homologation is for a S1600 rally car so to be able to use this mod, I think you would need to make your car exactly replicate all aspects of the S1600 which would be very expensive.
While the eligibility scrutineer has ok'd it for Wales, I think that the mod could be successfully protested.
Looking good!
