He said cheerful.Megane
Thats a great gesture mate, where are you? :smile:If your stuck and want to try another set of injectors I have a set of 182 injectors that have been cleaned and not used yet?
I could pop over one day to try them or ill pay postage and a drink for you?Only in crossgates so a stone throw away!
Back on track. @Christ Almighty where are you at with this problem atm? Are you waiting to visit efi or next step try different injectors? If you need a hand I'll happily pop round and with my expansive and diverse knowledge of swear words I'm sure we can make it better. I'll even bring a can of petrol just incase it's a lost cause. [emoji106]
Good luck next week then. Is the guy who was interested in buying it still interested or has he been put off?Hi mate, im going round to a friends in the morning to fit my new lambda as my jack is broken
Im booked in to see Chris at efi next week, he said hopefully it wont be too difficult to diagnose what the problem is.
I havnt tried the injectors yet as i dont have a spare set, ill see if scoff can let me know what the problem is before i throw anymore money at it.
Thanks everyone.
He is still interested mate, but i wont sell it until its fixed, its a lot of money for someone to spend.Good luck next week then. Is the guy who was interested in buying it still interested or has he been put off?
All cleaned up for you Tom.Hi mate, im going round to a friends in the morning to fit my new lambda as my jack is broken
Can a moderator please clean the thread up so we keep on topic?
Thanks everyone.
That's good then. I guess he knows a turbo'd clio isn't like owning a yaris then [emoji38]He is still interested mate, but i wont sell it until its fixed, its a lot of money for someone to spend.
Meg 225 mate.What injectors are you using, 182?
Hope u get it sorted soon palMeg 225 mate.
Ill either get one later tonight or tomorrow mate, thanks for any help its much appreciated:smile:grab a pic of an injector in the rail to show the plug and how the injector is sitting, unlikely to be the problem but the nozzles are 45 deg out to the clio ones so if they aren't in the right way that could make a bit of a difference. unlikely to be the problem but worth checking.
Grab a pic mate. I rekkon this could be your problemAlso when i ungplug each connector off the injectors, the engine note changes on every one, so im guessing they are all ok.
Although when i unplug cylinder one, because the injector wont shove in far enough and the little pull on the connector i can actually hear it hissing air out, but when i let go it stops, they just wont go in any further unless i file some plastic off the back of the fuel rail brackets so that it sits further in.
Ill pop round in ten mate and put them up, cylinder two injector fits nice and snug, the other three dont go in and you can see the o ring clearly not pushed in far enough into the inlet.Grab a pic mate. I rekkon this could be your problem
Im not too sure mate, they are all meg ones but one goes in fine and the others dont.Are meg ones shorter?
I will have a check tomorrow, the injectors are only pushed in the rail as they should be, just popped in, i will give everything a double check tomorrow and try your method of refitting, i did take my time refitting and adjusting and thats the best i could get them.unbolt your fuel rail and tip it down then push and the injectors should seat properly. then lift the rail back up and bolt it into place. also looks like your injectors are orientated the same as the clio ones, they need to be 45deg out otherwise you're going to have potential issues with port wetting. without looking in the flesh is guess at the injectors being pushed a bit to far into the fuel rail as well.
Propably not mate lolWould it surprise you if they are the wrong O rings?:smile:
what's wrong about them?
The o rings fit mate, but the injectors dont seems long enough to fit down the little pipes.To state the obvious, they are a very, very, very good fit.
