Clio Williams - Removing Inlet Manifold
Car  Williams 2
I'm trying to remove the inlet manifold on my Williams, most of the car is stripped so access is good (headlights/bumper/front panel all removed)
I've removed all the hoses/fuel lines etc, and unbolted the fuel rail but not removed it, do I unclip the connectors for the injectors first, the unclip the clips that hold the injectors in place to pull fuel rail off?
Or should I unclip the injectors first, pull the rail off and then unclip the electrical connectors?
Space is very tight and its almost impossible to get to the wire clips that hold the electric connectors in place
Any help appreciated!
