Trying to start bleeding (lines still dry) but want to check the system is ok first and it isn’t. This is the problem, am too dead to search for wiring diagrams right now if anyone knows about this or has easy access to the diagram?
I was having a similar problem with mine, main plug looks all good no corrosion , made sure it was all secured, tried some contact cleaner etc no luck, occasionally wiggling it made the abs pump jump into life so I removed the plug, sprayed the plug and socket with LOADS of contact cleaner, left it for 2 days then put it all back together and its been spot on since.
