Clunking noise front passenger side, top mounts?
Car  Clio 172
A few weeks ago I had a loud 'twang' noise come from the front passenger side when I took a right hand turn. Checked everything over, all seemed fine so I thought nothing of it. Over the last week or so every time I drive over a bump at low speeds (0-20mph) I get a clunking noise (think dropping a bag of spanners) from the front passenger side as the car. As time goes on the noise is getting worse.
I've read through the forums and it looks as if it may be the top mount loose, does anyone have a guide on how I can check this? The top 21mm bolt seems tight enough, but I can see where dust has been rubbed off under the rubber doughnut if that makes sense.
Any help appreciated.
