Clio Phase II 16V
I fitted a new clutch cable last Sunday and ever since ive had problems getting the car into gear sometimes ive had to stop the engine and put it into gear then restart the car.
Ive done a search on the site and read up on other peoples experiences, from this i tried the method where you remove the little green grommit and let the peddle adjust (you hear loads of clicking), this is fine until i put the gromit back in, the peddle goes slack and it sounds as if it has released the tension that was taken up.
My initial thoughts are that the cable is too long? as it is a patent part (dont usually buy these for this reason), secondly ive felt the toothed section and it feels like it has sufficient lubricant on it.
Your advice would be appreciated, as it stands ive taken the grommit out to get the car around but the peddle is so high, im sure this is not the best solution.
Tony
