Clutch Change on 172 cup (how long)
Clutch needs doing soon on ma car just woundering whats the genral hourly time it takes?
also is it a ass to do? and any tips along the way:P
thakyouuuuuuuu
there is a guide for doing it by dropping the subframe and removing the Gbox via the N/S wheel arch. Personally, I'd say 5 hours is unrealistic for a first attempt on the car.
^you can have the box out in 2hours if you know what you're doing
its just a bugger bench pressing the the thing back up onto the engine that causes the time
have done a 1.2 in 2 hours before just moving the box to the side
never really timed doing a 172 i've only done one but changing the box i reckon was somewhere near 5hr
reckon i could do just a clutch must quicker though just shove the box over and fit the clutch through the gap
yep thats what i done just chop a bit off the alignment tool and it JUST fits in the gap, ive got a few pics somewhere if you need any
i dont bother with the alignment tool i just finger tighten the bolts so it grips the plate.. then line it up with my fingers through the 3 gaps
try doing mgf clutches without taking the hydrolastic suspension out
gives you about 2 inches to change the clutch
its so tight you have to physically take the clutch out (undo the bolts with a spanner) to give you room to get the bearing out
