Coilovers & positive camber
VIICarCare
Car  255, 230, 172, R26
Hey guys, today I got my coilovers & hubs fitted. I will get pics up asap, then you will see what i mean :o
Firstly, the wheels are very close to the springs. They were rubbing at one point, so we had to raise them up abit to miss the spring. As my alloys aren't the originals, they slightly wider iirc. Spacers, is 5ml enough? I dont want the hassel of rolling arches etc!
Also, the front wheels have positive camber atm! Really noticeable camber, lolz. Now, Ktec do the camber bolts. Will these be ok? Im new to lowering etc!
The rears are pefect though! :D
So, thoughts & opinions please guys.
D.
i just got mine fitted and the guy adjusted the camber at the garage for the front, What coilovers have you got and what wheels?
you can undo the top bolt of the coilovers and pull on the bottom of the disc and it will sort out the camber. make sure the bolt is as far in towards the car as possible!
i would say 10mm spacers, depends really on how much space there is in the arch!
cheers Dweeb. The guy that fitted them has alot of experiance on cars so im sure he had tried that.
They are Rokkor & I have 15" Renault/Ronals on. Cant remember the exact measurements but they were deffo slightly wider than standard.
