Compbrake Top Mounts, Talk to me.
Rob
Ok, so how the fudge do I tighten these up?
I have a SRS single knock when I brake/sometimes accelerate and I found play in the passenger wheel, I changed the ball joint and this play went away, but alas this knock didn't.
I'm now thinking top mounts? I have compbrake items, but they don't look as easy to tighten up as the standard items... please help CS, lol!
they are rubbish. throw them in the bin and stick with the standard topmounts which are fine for the job.
i tried everything to get the compbrake ones tight but i couldnt stop them knocking and moving.
AST top mounts are awesome, one of the best mods ive done to the Clio, LOVE them.
How much are standard top mounts does anyone know off hand? It's driving me mental now tbqh!
The knock seems to be getting worse so its worrying, lol!
Is it just the C spanner to get the compbrake ones off?
Well if it is the topmounts, they're anything but fine, it's a real big knock. As far as I can tell there is movement in either balljoint now, when jacked up wheels feel solid as.
The only other thing on the MOT was "steering rack bushes slightly worn"
But I doubt that's going to be causing it is it?
Take it to a garage ffs! You've spent long enough thinking about it now and trying to sort it yourself! Take it to a garage and be done with it!
Unfortunately atm is £££ that's putting me off... I've got £100 left until payday, last working day of the month (pauper)
I guess I need to really but I've just been trying to avoid it. :(
P.s no one has answered how to undo the b*****d things yet....
standard top mounts are 37.30 plus vat from renault, i was looking at changing mine unsure which ones to go for
regards
sam
I have the Compbrake ones but never fitted them as I went the extra mile for the K-Tec package when I got my coilovers :o
Love the K-Tec ones! :D
OEM top mounts for me. Tried solid top mounts are they were horrific on the road. I just got a new set for the vee.
regards
sam
Is that for the pair or per side? (I'm guessing per side)
If it is what's wrong with it, I'd advise against ever fitting them!
Definitely not engine mounts?
Engine mounts... car went in to have drive shaft replaced a few weeks ago (around 5) and they checked dogbone and top mount, I've since replaced the cambelt cover, but not the mount itself as it is fine.
The mounts wouldn't cause the steering wheel to jerk either would they?
It really feels like its coming from something in the front arm/suspension.
Are they model specific? Or are all mk2 ones the same? I've read varied opinions...
didnt someone say the compbrake ones are slightly too small for the hole?
i just bought some 182 rubber topmounts for £17 each from euro car parts
UPDATE:
£17 each??? My local factors wanted like £37 each or something??
I'm a happy man, the knocking has started being more frequent, and I can not pretty much 99% tel its from the top mount :D
Once I've got these off, it should be larvely!!
How do I get the compbrake items off? Undo the nut on the top then undo the rest with a C spanner???
Indeed I am Mike, you can pretty much feel its the top mounts now, you can get it to "clunk" if you turn left full lock too.
Going to try some standard ones with the washer fix :)
How long will it take us to shove some on? ;)
lol! Fair play, I've done suspension before so I can be more of a help though :D
Although I haven't got a clue how to get these fecking compbrake things off, and no one seems to want to help! lol!
Does the spring/shock have to come right out to change the top mount?
could use a C-spanner to undo the lock ring (same as coilovers in effect). If that's a no go, loosening the ring with a blunt punch/drift/screwdriver and a hammer is viable. You'll find some chewed up O-rings when you get it apart.
Whole shock/spring assembly has to come out to remove them
danny - is it just the ecp top mounts which you think are s**t or the oe items in general.
mine is now a road only car track days are behind me now and i know fred rates oe topmounts , wonder if these ecp ones are just made of even poorer quality jelly than the renault ones.
