correct rear brake assembly?
Car  CLIO Iceberg 172
Hi guys. i need some help with the rear brake assembly. i need to know the correct order in which the brakes go back onto the rear hub up untill the hub nut.
as far as i can tell there are a numbet of washers and spacers that sit each side of the disc and bearing before the hub nut gets put on and tightened.
dose anyone know what should go where?
have had a good search thru and cant seem to see anything. and im really unsure of the order since i did a full change.
cheers
spacer
disk
pad carrier
pads
L bracket and retaining clip
pad spring clips
Hub nut tightened to 175Nm
