Cracked rear brake disc
Jun
Car  Pearl Black 172 ph2
Just discovered that my right rear brake disc has cracked :dapprove:
Now I'm a bit of a noob when it comes to this... so where would you guys recommend that I get a set of discs from and how much I'm I looking at spending?
Also is there anyone local who can fit them for me? :o
holdcroft renault, stoke were selling them for 75 quid mate with bearings and abs rings fitted. i had some off them a couple of months back;)
any motor factor will do them such as gsf. but i think at the moment renault themselves are about the same as ourselves, bearing in mind the rear discs come with the bearings. they're normally stock items too.
pm gray, he's up your way and may be able to do them or fred @ btm is in birmingham is recommended.
beleve it or not but renault is the best place to get them from and the also do a set of budget pads for the back too. probly cost you about £100 more or less all in.
Cheers for the info guys. Looks like Renault would be the best place to get them.
Thanks for the offer mick :) I'd like to see if there's anybody a bit closer first though :p
Renault are the best place really dude, always in stock.
Although Fred may do them cheaper?
I can fit them for you in about 20 mins?
