Quote: Originally posted by anthonyj207 on 14 May 2003
Why do people with ABS believe they are Invincible?????
At no point did I say I was invincible I mearly stated that an ABS equipped car will stop quicker in wet and dry conditions.
If you react too late/brake too late, or the conditions of the road are bad (wet/icy) YOU WILL CRASH!!!! ABS or NOT!
True, but that is the case whether you have ABS or not, however at least if you have an ABS equipped car you can try to steer around the obstacle hence preventing said crash !
performace degrades in wet/icy conditions
Err. it does that on non ABS equipped cars too, its called lower levels of traction due to water and ice acting as a lubricant.
but does however allow you to steer the car (unlike non ABS which will lock you up in whatever direction you are currently pointing - sideways usually!!
The whole point of ABS, the reason it was created in the first place.
ABS does NOT make up for bad driving or poor reactions!!!
True, it does however assist bad drivers in getting out of the situations.
