Coupe/Defender V8
Re: My Phase 1 ITB Daily Runner
loll how was your trip mate
just had a read of this thread.. omfg im not the only one in the shocking mapping boat then!
lol! Hi. I've heard of your troubles Kevin. It's not really a boat mate tbh it's more of an aircraft carrier lets be fairGlad you got it sorted.
Lol another one!!
I'd love to have a quick drive of somebody elses ITB'd car with a different persons map on to see if i can tell the difference.
My car runs and goes realy well. I wander if i could tel the difference?!
We fully accept, as do Pipercross, that we had to recall the ITB Filter in it's first encarnation. All customers including yourselves were advised of this within 2 hours of our demonstrators failing, we were in France when we made the call! You received Pipercross Socks as an immediate replacement.
running to much ignition timing? running at the very bottom of the lamba sensor? meh need i go on?
Michael,
It isn't as easy as chapter over i'm afraid. The facts are simple and they are as follows:
1. Your vehicle was calibrated using the sausage filter, on the Jenvey Set Up, the the Omex ECU, here on our rolling road. AFR was bang on 13:1 Graphs prove this. - Graph is invalid - dated November from ORIGINAL Calibration
2. You air filter was replaced with more restrictive socks. You were offered the replacement ITG unit, you declined due to the imminent arrival of an airbox. - Was not offered replacement - bought individuals off my own back - after having second pipercross sausage filter, which I suggested mesh needed to be thicker - was not noted - and had to pay for replacement
3. The restrictive socks caused the car to run rich at the low load and partial throttle sites of the map, causing a flat spot of sorts, you asked us to look at this for you.in a manner which wouldn't cause the car to run dangerously lean, and properly calibrated - never asked for it to be done on the road
4. Andy made amendments based on road driving and experience having developed this kit during his time at Omex, which originally included socks. The effects that socks have over the sausage filter are well known to Andy. -Then why was it left running lean?
5. You took the car away happy with both the changes and the overall drive. I was happy until I found out how it had been left, yes. At which point I contacted you. denying all responsibility
6. The next we hear is via email calling our calibration "piss poor" and generally throwing your toys out of the pram. no toys, just a tremendously awesome feeling that I'd had it corrected in time.
7. No explanation, no detailed reasoning, no opportunity for us to understand the problem if indeed there was one.I think you owe me a legit explanation before I offer you anything.
8. You start badmouthing us, PM'ing other members who have declared interest or have our calibrations to warn them of our "piss poor" calibrations.No comment
9. We have now challenged you as to why. Because my car was left running 13.8:AFR under load.
10. You want to run away. I'm still here
Did you not think we would react to your claims Michael? Can you not understand the severity of this situation?
Sean.
Michael,
We cannot send full calibration files, this is common practice. The changes can be seen clearly from the fuel map screen in GWV4, would this be acceptable? You cannot view a map file in its entirity anyway, you were after the changes made I thought?
Perhaps you can screen shot your fuel map table and we can compare them with the same from GWV4? As you know they use nominal figures, so percentage change is what we are looking to compare.
To address your other points:
1. Any changes to the fuel map were below 30% throttle so would not effect WOT runs, therefore the graph is as valid today as it was then. Prove it
2. You were offered the filter in person by Bex, here in our reception. We told you were still eligable for a FOC replacement ITG unit, even though you had ripped your old unit off and thrown it in the bin. Remember?because even after 2 of the other products that weren't fit for purpose and sub standard, you were going to charge me for it
3. You asked us to look at this one area only, on the road or on the dyno, partial throttle is trimmed the same way. -why was it left running lean
4. We seek to prove it was not left running lean. - refer to my afr before and after
5. So you were told the car was dangerous, who by? -no comment
6. No comment
7. Surely this is what we are working on right now, sadly in full public view.
8. I wonder why no comment here, we have proof of this Michael, plenty. -that's lovely - have plenty of people offering me advise, if you want to try and discredit them too...
9. Again we feel this was not the case and are working to show this -then bloody well show it
10. Good.
Sean.
Haven't received it yet.
