Decat pipe help
Car  clio sport 172
hello i'v got a problem with my decat pipe and the gear link bar (the black bar).
when i shift to the 2 and 4 gear the black gear bar is slightly touching my decat pipe so the gearstick is vibrating and it produces a buzzing sound...is there any chance to make a bigger gap between the link bar and the decat pipe? or wrap the link bar with something?
any help is appreciated
all 3 engine mounts are new (oem) + powerflex dogbone, the decat pipe is 63,5mm
thanks in advance!
Does your decat have slight anlge in it, if does then the pipe may have dropped and moved to the side, it could also be the gear linkage as well tho
Have checked all of your exhaust mounts as well
exhaust mounts all new also, when the car is in neutral it's ok, but when your driving the bar touches the decat pipe every time i shift in 2 or 4 gear.
no, fred it's the supersprint race one 63,5.
do you maybe know how could i make some little gap between the pipe and the link bar?
