Decent brakes
Car  1.2 16v (Race Spec)
Can anyone recommend some decent discs and pads for a 1.2 16v please? As the winter weather draws in the roads are getting worse and my brakes are squeeking and all sorts! Would like an upgraded setup really, not a disc setup on the rear because it's still only a 1.2.
Standard disks are good and I'd go with standard pads of just Halfords standard ones. I've yet to have any trouble with there pads. I wouldn't recomend any harder pads for winter as you don't want them to be difficult from cold.
If you want get some 4 pot brakes up front but its overkill for a 1.2 realy .
change brake fluid maybe the only thing that edde hasn't said really.
4-pots are available from k-tec / Richspeed.
/y0z
:) hello
send you photos of my new discs etc if you send me your email address.
go on ebay and type clio discs theres a company called sportbrakes that do good quality drilled and cut discs for all models.if ordering tell em muckytools advised you.new pads a must try pagit or ebc theyre about £65ish for 1.2.
ps for all those people who will say yeah but theyll be crap quality.:nono:
theyre AP discs and ill mail anyone pickys of my discs-
and theyve been great and work better than my last red dot customs even on track.
Ooops yep your right Yoz that can usually be the biggest thing I've found to help only remembered after I posted.
I don't wish to desput your claim Muckytools but I've seen drilled disks block up and crack on track days.
You don't need uprated pads realy I track my car on standard disks and Halfords pads with normal fluid without any trouble.
Bleeding the whole system will help though. I don't recomend harder pads unless you've had fade before though as for £65 there quite expensive next to the £30 Renault ones or £15 Halfords one which are fine.
