If you're using tough coat go with tripple mate. Lime prime can be a little fussy although via rotary it's a superb product.
Tripple on a light pad will work fine on the rotary once the pad is primed correctly. Keep at low speeds and just see how it goes. Very good product.
You had much use out of Tripple Dave? Good results? I think it's a great product, especially as a modern Srp product, much better!
They should make their Glaze similar without the carnauba content. Rejuvenate but a bit more glaze like, slicker and more fillers.
I applied G1 the other day, obviously it's not as easy as RainX, but it wasnt that bad to apply.
I'm probably the only bugger in the UK who wants a bit of rain now lol! I want to see if it works as well as I've seen on others cars.
You missed a trick, I was applying Wolf's to the new windscreen on the stand while he took my other one off last Sunday.If you're a regular driver in the rain, being without it is really noticeable. I really took it for granted till I had my windscreen replaced
I currently have a couple of coats of gtechniq C1.5 on the front end of my car and im pretty impressed... but as per usual i keep hearing people banging on about AF Tough Coat and im a little intrigued. is there a massive difference between the two and has anyone had any experience with both?
There's is a big difference in terms of what they are. For eg Tough coat can be used over most things like glazes etc C1.5 is more a nano style top up. TC is similar to an old fashioned spray sealant like Werkstat Acrylic.
If you're looking for something similar Autobrite's Project32 might do.![]()
Anyone used the Mint Merkin glass cloth? Glass is doing my nut in at the moment. My MF's are quite short pile aswell!
What's recommended to get out 1200 and 2000 grit marks?
Interiors. Talk to me.
Well mainly about carpet and seat cleanliness tbh. I want to give the seats and carpets a good wash as they are 5 years old now. Any top tips? I want perfection.
A higher grade of paper tbh, followed by a polish via machine.
Tbh kev ive already tried this and i has come a bit dull on the underneath the foglight
Just wandering what other solutoins there are.
G1 is the only thing worth bothering about mate but rain x isn't a bad alternative. Just won't last that long really. It's also the same price as G1. False economy.
Just buy G1 apply 1 layer with a make up pad and then remove it. Then sell it to me.You'll use like 2 ml and it'll last for ages.
