Shhh
				So there we go, £900 on eBay buys you this. (2003 expression)
Wanted to remove the rear tints from the windows & the rear window, drop it back to a normal car and remove the wheel trims. Remove the parcel shelf to show that its empty, as i will be using it to work and back (80miles a day) in the short term.
I go out to remove the tints using the steamer method, but it seems that its not actually film but its painted on. The windows are etched from build..so im stumped..? Anyone?
ECU Loom - The metal cover at the back of the engine is loose, can hear it rattling away. Was going to lose it as its just annoying on the drive home. Apparently the loom rubs on the metal unit. Is there a modification to stop this? I have carried out a search, and no guides were found.
I had one of these brand new in 2002, hence the reason for buying it. Loves to sit at 50-60mph, but eats fuel at 70mph..
