different aerial for 172
Gus
  182Turbo,DCi90
I park my 172 in my garage every evening but ive got a problem. Due to the aerial being a 40 cm bee sting type , it catches on the garage door when i open/close it.The garage is a swings up and over type. the aerial gets pushed towards the mount and flexes it.
I was wondering if its possible to shorten the aerial or get a different one. I wouldnt mind one that looks like the new BMW middle fin design.
I listen to the radio everywhere I go so I must still have good reception.
Oh, and does anyone have any ideas as to what i could use to to stop the car driving too far into the garage, should i screw some chocks into the floor or something.
Gus
  182Turbo,DCi90
Thanks, looks like I will get a CTR one. How do you go about replacing it? Is there a nut under the roof paneling that releases the aerial. also have you got any tips on making the replacement 100% waterproof so i dont get leaks.
Djw John
Scotland - South
Agle grinder, just take a square out the roof, weld in a new panel, new aerial base and bobs your mothers brother :p
Or if it really is jammed then get a new base from a breakers, you just need to take the overhead light out and get a ratchet onto it.
BTW dont think that i can get that 15mm for you, sorry dog
