You can fit the fuse box back in place but its tight, the big black relay box needs to be moved though, I have it placed inside the glove box cable tied down, the glove box on my car is screwed shut anyway so I wont be keeping my lip stick in there,
When I fitted the cage I wanted it to stiffen the body as much as possible without being welded in, I jacked the cage up as high as i could get it, putting pressure on the roof skin and fitting tighter between the b piullars, then made my mounting plates to suit, This is why the back stays are not on the floor.
If I said its tight, it would be an understatement and needed a porta power to get the cage back in once the foot plates were welded.
Hope that helps
Hope that helps
