Disc Brakes conversion.
Car  FFFFFFFUUUUUUUUUUUU
How easy and cheap is it to convert the drum brakes on a Mk1 1.4 RT to disc brakes? and how easy is it, possible to be done by a begginner or a cheap proffesional job?
16v beam will not fit - as someone said above you need an RSi rear beam as teh 16v is too wide for the RT body. IMO it's not worth it as it won't making a major difference to braking performance. Best bet for improved braking would be to get 16v brakes on the front. You just need the calipers, carriers discs and pads.
Spose it does look better, drums look w**k! especially if you're trying to make your car look a little sporty, soon as anyone see's drums on the back they know its rubbish :p
yeh u can stick a sport badgeon the back then and sya look it even has rear discs!
