Disc Brakes conversion.
  FFFFFFFUUUUUUUUUUUU
How easy and cheap is it to convert the drum brakes on a Mk1 1.4 RT to disc brakes? and how easy is it, possible to be done by a begginner or a cheap proffesional job?
Paddy_g46
easy but can u b bothered?
also can u just put brake hoses on the end of the exisitng lines?
  S2000
16v beam will not fit - as someone said above you need an RSi rear beam as teh 16v is too wide for the RT body. IMO it's not worth it as it won't making a major difference to braking performance. Best bet for improved braking would be to get 16v brakes on the front. You just need the calipers, carriers discs and pads.
  Valver
Spose it does look better, drums look w**k! especially if you're trying to make your car look a little sporty, soon as anyone see's drums on the back they know its rubbish :p
Paddy_g46
yeh u can stick a sport badgeon the back then and sya look it even has rear discs!
