Do I have an RS intake manifold or am I going nuts??
  Clio 182 Blue
Hi guys
Had my 182 a good 8 months now, Today I lined up with a fellow 182 (Blue, oldish bloke cardiff area?), anywho he gave me a nod and a rev as you dooo, so took this as a bit of a race.
Lights turned green, 1st 2nd we were both struggling for grip and pretty level, then 3rd 4th 5th i blew him out the water..
I'm intrigued as the bloke i bought it off said this seemed a particularly quick 182 i just nodded along at the time.
I decided to investigate as I've seen on ebay a couple RS mani's up and was contemplating buying one
Had a look in the dark, couldn't see anything so wapped my phone in and started taking pictures
Could see fook all then i saw the picture below, is that an S? or am i seeing things..
I'll have a propper look when i get time in the light... and when it stops snowing!
Flat Eric
Sing Hosanna!!
  F31 35d, Berlingo Na
Wouldn't say having a 'RS' manifold would make much difference in the sense of blowing another 182? I could be wrong though.
Don't all/most 182's have this manifold anyway?
DaveDreads
My 52 plate 172 has RS inlets,
I think the French just grabbed which ever inlets were at the top of the parts bin when they were putting them together.
Flat Eric
Sing Hosanna!!
'Jesse don't. He's got more than a hundred quid under that bonnet, RS inlet!"
  Clio 182 Blue
Ohh you guyss..
From the way people go on about RS intakes I thought they were Renaults gift to the world. -I now know better..
I think I may have a wee remap in there. I get 44-45mpg at 70mph, which seems a bit above average. And at 5krpm it kicks like i have a bo... ??
But then again could be my shiny new plugs or box pffffft :lolup:
Flat Eric
Sing Hosanna!!
You run it on Vpower don't you. Thought you did. That's your answer.
  Clio 182 Blue
I thought they advance the timing top end for more power and reduced it low end so you use less fuel unless you gun it..
With a race set up they'd smooth out the entire thing and make it rape fuel for power
I fancy a dyno trip, anywhere in southwales anyone know of?
  330i. E30 Touring.
Flol at a map changing the timing.
Nope, Tony was right. He backed off as the weather is shite and you're pushing up into silly speeds.
  Nippy white cup
Also you could have a good std engine that would batter a filter/exhaust/decat/map that needs all that work just to get it to std ish power....are you getting RS mani confused with RS2 setup?
  Clio 182
I still don't understand the exact difference between an 172 and 182 inlet?
It's not only the RS on it, are they better matched or is it something else?
Has someone a before and after RS182 inlet bhp grafic?
