Dogbone mount change???
  E36 M3. 182
Hi all, just in the process of changing my dogbone mount, It looks stupidly simple, undo 1x19mm bolt and 1x16mm bolt and bobs yer uncle (remembering to support the engine while youre at it). However, the rear bolt (16mm) seems extremely tight, is this because I havent taken the fromt bolt out yet to relieve the load from the rear bolt, or do I just need to man the f**k up and strap on a pair??? Or am I missing something else??:S
  E36 M3. 182
Sound, 1/2 inch drive breaker bar with 6 sided socket and a scaffolding pole should do the trick then??
