Dropping subframe help?
Car  Ph1 172
Ive taken all the bolts and everything off, the only thing left holding the subfame on is where the steering colum meets the rack. This is where im haveing the problems ive taken the nut off and cant split the colum from the rack. help much appriciated thanks
Do you not have to remove the bolt aswell as the nut?
Mines fell out easilly once i done this. double check everything. make sure you have all the bolts out
nut and bolt out you may have to get a flat blade to get it to part do not pull down on the column though
Thanks right i have done that, theres one more thing holding the subframe it seems to be a pipe wrapped in silver protective wrap near the rack?
