Was thinking of getting the above, it fixes on by a clip which hooks onto the inside egde of the boot lid, it then has two holes for fixing to the boot lid. The first thing that comes to mind to fix it is bolting it, and then you realise that you have to drill the hole for the bolt and then cut a hole largenough for the socket on the inside edge of the boot lid. I suddenly came up wiht the idea of pop-riviting it, this makes the job instantly quicker and means less cutting inot the car body.
Would pop-rivets be strong enough dbearing in mind that the one end of the leg is clipped to the boot lid, of should i stick wiht bolts and washers?
