ECU :S
Hi, got a 1.2 16v Y reg clio with buggered ECU, on a mk.2 do I just need the ECU? or do I need other bits aswell?
you could just get the ecu if you wanted but you would need to get it coded by someone to your key and uch.
or if you want to do it by yourself you need to get Ecu,UCH (a box behind the fuse's in the car) , key,key barrel and key reader(black thing around the barrel)
that should cost about £150.
also make sure you get it off the same phase as yours
phase1 1998-2001
phase2 2001-2005/6
phase1 1998-2001
phase2 2001-2005/6
Easy swap will be "ECU, UCH + Key Fob"
Alot of people think the black ring is coded but its not. Also the metal key pulls out the key fob so you don't need the barrel or key.
We sell the set for £130
