Electrical Gremlin on Sequential Box
Grats
  Rally Car
Any thoughts on an unusual electrical fault on my Clio Rally car. Well unusual to me, might be something very simple.
Problem - Car is running a sequential box with custom built digital gear display.
The Sadev gear position switch and gear position display work on 5v supply. They are fed from a 12v to 5v converter.
Everything works fine until I turn on the interior fan. Then rather than having 5v feed out of the converter it is 12v out and in and of course the display stops working.
Tried a dedicated earth and 12v supply direct from battery in case their is a cross feed or bad earth - no luck.
Thought it might be an earth fault but everything seam ok and would expect more issues?
The loom is a stripped down standard loom, using same fuse box, loom came with shell so can't be 100% sure what's been done.
Any thoughts, guesses, testing ideas.
Grats
  Rally Car
Done a bit more testing, even more confused.
Right with the internal fan switch off the 12v to 5v converter gives a 5v supply, with the fan switch off but fan itself unplugged it gives a 11v output. With the fan still unplugged but internal switch on any setting get 12v instead of 5v. Any suggestions??
Grats
  Rally Car
hi Sam
Ran a supply direct from battery and a dedicated earth, and just the same, works with fan connected but not turned on, turn fan on (setting 1 ,2 or 3) and voltage jumps to 12v. If the fan is disconnected and then turned on jumps to 8v on setting 1 and 11v on 2 and 3 speed settings.
Grats
  Rally Car
Hi, don't think I have measured this, will try to have a look tonight.
For the next event a roof vent is being installed.
Grats
  Rally Car
Hi Sam - tested voltage across battery and no noticeable voltage drop with or without switch on, plugged or unplugged motor.
Grats
  Rally Car
All sorted I think, one of the fan actuator wires which are not used was cross to earth, so when fan on feeding back.
