electrical issue please help?
Car  172 FF
My fog lights dont work, yet when I use the wash wipe on my wipers the fog light flash what can that be. I checked the fuses when i first noticed they had stopped working. Then I checked all the relays. Im not sure what it could be maybe a bad earth?
The car is a 172 02 plate not sure if this makes any difference to the wiring.
A bad earth is the most likely cause as both switches are negative return relay operated.
It could also be a sticking relay or a trapped loom.
Have you fitted anything electrical recently ?
Whip the top cowl off the steering column and all the wires will be visible, look for a stud with several brown wires fixed under it.
I have only had the car a few days so ill have to check that. I only checked the relays were in correctly not if they were sticking, ill have a look thanks.
