Electrical problem phase 1 172
Tj172
  172 Track car
A mate of mine has a phase 1 172 and it keeps popping the 30amp fuse that controls some engine components, located in the engine bay fuse box. Ive had a quick look over the car and a few things have stood out. There is a unplugged plug located by the eb fuse box, that has had wire stuck in the end to bridge the connection (trying to attach a pic) whats this plug for orignially? Also a sensor on the inlet plenum that has been uplugged and some form of resistor block plugged in instead. Again any ideas? Were still going over the car and i need to get it up in the air and check the lambda wires arnt burnt through, causing the 30a to blow. Any light on this would be great.
