Engine Bay / Grill Stickers
MarcB
Car  Vw Golf
So there is a few people asking about the engine bay stickers there are no longer made by renault and are not available from Renault France or UK.
As like most I was looking for a solution I went and checked my 197 stickers and seen that even tho they are different they still have the same info and are the same size.
@fatboymal @VenomUK @Archtronics
The sticker on the right of the grill is still available from renault.
Thanks @MarcB ! (y)
Just to add to the above, I have also found that Renault engine bay decal 7700423730 will also be a suitable replacement for the original stickers that came on the Ph2 172.
It is a longer decal, but as pointed out by MarcB above all the info is the same - just need to make 2 cuts and then you can get both the left and right decals out of the one :)
Original (no longer available) with new 7700423730 above:
The cut ends of 7700423730 form the sticker for the right side (as MarcB showed above, original is 8200244633)
Renault had it here in stock in Australia, so would expect that it's still available in the UK - and probably costs not much more than a fiver?
I will add that I think this is also an option for Ph1 172s as well, just need to cut the 'cooling fan' panel off
