Engine Cover Screw rounded off.....
santoz
Car  Clio 182
One of the screws on the engine cover of my 182 decided to round itself off :(, the other three weren't too bad to get off loads of WD40 and heat but now i've no way of getting the fourth one out :eek:.
Any ideas?
Not enough room to get my dremel close to cut a flat line out of either :(
superglue an old screw driver head into it. Make sure you dont want to use it again. You will have to buy a replacement bolt but should do the job.
just hammer a flat screwdriver, torx or anything really thats oversized in to it
they arent really tight
if all of the above fail try drilling it out then when the cover is off get some molegrips or pliers on the stubs and they should come out, i had to do this on mine a few years ago..
going to try banging a bigger torx head on it.
Where i'll get a new bolt, is it a standard size or special (lenght) Though i'm sure i could just get the dremel out and modify the lenght :rasp:
