Engine/gearbox whine?
  Audi A3
good morning folks,
quick question, when accelerating in first (not harshly just normal) for the first few thousand revs i can hear a mild whine type noise. ive read a few posts and tried to establish what it could be myself but with no luck.
Is this a general/normal sound or problem sound?
cheers guys
  350z GT
I have this at the moment....can hear it in gears 1 to 3 when windows down
im going to change the gearbox oil and see if that helps...im pretty sure its the gearbox and not the engine
  Audi A3
Mine does it slightly when I first start up, gearbox feels fine when changing, no clunks or harsh sounds/feelings
  Clio 182
Aux belt kit. They're quite whiney aparently. No need to worry. Mine does it, it sounds a bit like a supercharger.
  RB 182 Cup
I've just had a new aux belt at Renault and ever since I get this too. Seems to be worse after starting and then quietens downs to a gentle whine that I can only hear when not moving.
- Sent from my iPhone using Tapatalk
  Clio 172
Mine also does this. At first I suspected the aux belt, but after having the belt, pulley and tensioner replaced it still makes the noise.
When listening closely it seems to come from the bottom of the engine, so my next suspect is the gearbox. I'm going to try changing the oil to see if this helps. Doesn't seem to be causing any problems but its annoying to have the sound there.
-J-
  RS2'ed 172 Cup
It could be the gearbox syncros being worn.
One suggestion... If it is the box don't get one from Renault! See my thread in the Dealer / Trader review section.
