ENGINE HELP!!!!!
Car  172 PH1,Skoda oct VRS
Hi guys i need your help got a phase 1 172. Just on way home from work, stopped at a roundabout then, went to pull away and car started miss firing!! It jerks up to 3k. Sounds almost like a impreza with the way it now rumbles. The accelerater pedal jerks too. Not sure what it is think it could be on 3 cyclinders? Just worrying if its cam belt related? Anyone have any ideas?
Regards
Chris
Coil pack is likely, on my ph1 the power lead came off one of the injectors which caused the same symptoms!
