Engine knock/rattle NOT DEPHASER
  F4r'd Clio 1.2 16V
Hello
the car has developed a strange tap/knock/rattle when on/offing the the throttle, I looked on youtube and the closest thing to what mine sounds like is this video
http://youtu.be/3nrhsjsM2_0
It's not the dephaser as that has very recently been changed it sounds like a heat shield rattle but worse and on idle it does not do it, likewise when you hold the revs.
jack
aucky
  N
The ticking at idle is probably just the valves. It's much more prominant with the RS2.
I'm not qualified to judge the grinding noise when revving though.
  172 Cup
If it's knocking when you apply thottle (thus applying a change in torque), then could it be engine mount related? Have you checked the mounts recently?
  F4r'd Clio 1.2 16V
I appreciate the replys, the thing is I had the dephaser changed as this was the last problem I had, the noise doesn't get worse when it's hot like when the dephaser is going, it does it when cold and hot and is fine on tick over, could it be to do with my lifters? Seeing as the engine has been in the garage for the last 6 months or so?
​jack
  Lionel Richie
Lifters never fail on these, who did the dephaser? and are you 100% sure they actually changed it? (daft question but hey!)
  Lionel Richie
Edit, just watched the video again, the "off and on" bit, 1000000% dephaser, take it back to whoever did the work, new parts have 12months warranty
